美光UQD正確說明
The UQD will not prevent a quality wax from sticking to the paint.
UQD不會擦掉你車上已上過且固化的蠟
Use a clean, quality microfiber polishing cloth to wipe the car clean using UQD and then apply your favorite wax.
使用一條乾淨, 高品質的超纖布用UQD清潔擦拭車身, 然後上你喜歡的蠟
轉至:
http://www.meguiarsonline.com/forums/showpost.php?p=263498&postcount=2
UQD is a little different in that it leaves behind a special polymer on the surface and repeated applications will reach a plateau of this polymer coating on the surface.
UQD有點不同(這邊指跟QD比較), UQD擦拭完後會留下特殊的聚合物, 重複使用會在表面形成一個平坦的聚合物膜
You can't add more and more UQD and create a thicker and thicker layer of this polymer coating but you can create a uniform coating.
你不能用更多的UQD, 使得這層聚合物膜越來越厚, 你只能使得這層膜更均勻
轉至:
http://www.meguiarsonline.com/forums/showpost.php?p=250744&postcount=5
UQD is a quick detailer, note the spelling of quick detailer as quick detailers are a category of products referred to as "Mist & Wipe" products,
UQD是一種快速美容液, 注意拼法是quick detailer, 就像其它在目錄上的快速保養液產品, 可以參考"Mist & Wipe" 類產品
that is you mist the product on and then spread the product around and then wipe the residue off with the idea being to remove light dust, fingerprints and smudges[/color].
這種產品是你可以用噴的方式把產品噴上物體, 然後你把它擦拭掉, 以達到移除輕微汙垢, 指紋和汙點的目地
Now we make a number of quick detailers and one of them is named Quik Detailer, so it has the same name as a generic name used to describe a category of products but
我們現在製造了很多快速美容液的產品(可以點選連結), 其中之一是Quik Detailer, 它在產品目錄裡有相同的名稱來描述, 注意quick和quike, 拼法是不一樣的
note the spelling of the word quick and quik.
Ultimate Quik Detailer is a "Mist & Wipe" product, not[/color] a spray-on wax[/color] or a spray-on sealant.[/color] It is a blend of different types of polymers, now many and what they are
UQD 是一種"噴完擦拭"的產品, 不是噴蠟, 也不是噴膜, 它是多種聚合物的混合, 美光沒把它貼在論壇上, 因為它是一個商業機密
Meguiar's is not going to post to a public forum as that's proprietary information. This formula does offer some protection against attack and deterioration but again it is [/color]
UQD的成分提供了一些程度的耐刮和漆面衰退, 但重申, 它主要還是"噴完擦拭"的產品, 其主要功能為移除指紋和汙跡, 不是噴蠟或噴膜
primarily a mist and wipe product for removing light dust, fingerprints and smudges, not a spray on wax or a spray on sealant[/color].
We want you to love this product just like you like our other product but we don't want you or anyone to have unreal expectation for it. We like to under-promise and overdeliver.
我們希望你愛上這種產品就像你愛其它產品一樣, 但我們不希望任何人用不真實的解釋來解釋它, 我們願意在產品保證下來提供大家保護性的噴霧產品,
它們是Quik Wax和NXT Spray Wax
We do make spray-on protection products, these would be Quik Wax and NXT Spray Wax.
轉至:
http://www.meguiarsonline.com/forums/showpost.php?p=218691&postcount=3
我的個人總結:
1. UQD不會越塗越厚, 且不會蓋紋
2. 上完蠟, 不要馬上用UQD, 它會把你沒固化的蠟當汙垢一樣也一起擦掉
3. 上蠟前先噴塗UQD, 會使漆面更乾淨, 且有一層聚合物, 使得上蠟效果更好
4. 平常洗完車, 把車子擦乾後, 再用UQD噴塗擦拭, 可以去除輕微油汙且留下一點保護性的聚合物
而這時, 並不會把你車上原有已固化的蠟清除掉, 可作為日常快速美容用
=====================================================================[/backcolor]
[backcolor=rgb(247,247,247)]=====================================================================
UQD不會擦掉你車上已上過且固化的蠟
轉至:
轉至:
轉至:
我的個人總結:
1. UQD不會越塗越厚, 且不會蓋紋
=====================================================================[/backcolor][/color]
[backcolor=rgb(247,247,247)]=====================================================================The UQD will not prevent a quality wax from sticking to the paint.
UQD不會擦掉你車上已上過且固化的蠟
轉至:
轉至:
轉至:
我的個人總結:
1. UQD不會越塗越厚, 且不會蓋紋
UQD不會擦掉你車上已上過且固化的蠟
轉至:
轉至:
轉至:
我的個人總結:
1. UQD不會越塗越厚, 且不會蓋紋
