[size=10pt]Use [color=#eb15e]Chemical Guys Polishing & Buffing Pad Conditioner to keep your pads clean. You can also use the [color=#eb15e]Grit Guard Universal Pad Washer[/color].[/size][/color]
[size=10pt]
[/size]
[size=10pt]
[/size]
[size=10pt]
[/size]
[size=10pt]
[/size]
[size=10pt]
[/size]
[size=13.3333330154419px]小白求教! [/size]TORQ10FX 不会是RO 吧! 我是看亚马逊摆在一起对比!
			| [size=10pt]Specifications[/size] | |
| [size=10pt]Part Number [/size]  | [size=10pt]BUF_501[/size] |
| [size=10pt]Manufacturer Part Number [/size]  | [size=10pt]TORQ10FX[/size] |
| [size=10pt]Speed Control [/size]  | [size=10pt]Yes[/size] |
| [size=10pt]O.P.M. [/size]  | [size=10pt]1,500 - 4,200[/size] |
| [size=10pt]Power[/size] | [size=10pt]700 W[/size] |
| [size=10pt]Weight [/size]  | [size=10pt]5.5 lbs [/size]  |
| [size=10pt]Energy Efficient [/size]  | [size=10pt]Yes [/size]  |
| [size=10pt]Safe for Enthusiasts [/size]  | [size=10pt]Yes [/size]  |
| [size=10pt]Safe for Professionals [/size]  | [size=10pt]Yes[/size] |
[/size]
| Electrical Cord | 6' 4", Insulated |
| Motor | 110 volt, 4.5 amp (500 watt), max unloaded speed 6,800 RPM |
| Pad Speed Range | 2,500 to 6,800 oscillations per minutes (unloaded) |
| Case | Double insulated, ABS plastic |
| Weight | 6.2 LBS |
| Backing Plate | 4.75" diameter, flexible, with hook & loop [color=#ff00]BACKING PLATE FREE[/color] |
| Foam Polishing Pad | 6.0" diameter, reticulated polishing foam |
[/size]
[size=10pt]
[/size]
[size=10pt]
[/size]
[size=10pt]
[/size]
