精华主题 曼泽纳抛光剂/研磨剂与湖国抛光棉盘搭配一览表 - 转自Autopia/Camaro5
论坛各板块通用的精华主题标签
新糖果 发表于 2013-11-29 13:18
H2O系统里还有一款红棉,这个貌似没有切削力?
Hydro Tech的棉盘是这样的
[float=left][backcolor=rgb(0, 0, 0)]Most Aggressive[/backcolor][/float][/align]
  • 6
  • 7
  • 8
  • 9
  • 10
  • 11
  • 12
[align=left][float=left][backcolor=rgb(0, 0, 0)]Least Aggressive[/backcolor][/float]​
  • 6
  • 7
  • 8
  • 9
  • 10
  • 11
  • 12
H2O-44-9600KR61 1/4Cyan Heavy Polishing - KompressorHook & Loop
H2O-9155-130MM5 1/21 1/4Cyan Heavy Polishing - DA PadHook & Loop
H2O-9165-152MM6 1/21 1/4Cyan Heavy Polishing - DA PadHook & Loop
H2O-9255-130MM5 1/27/8Cyan Heavy Polishing - DA PadHook & Loop
H2O-9265-152MM6 1/27/8Cyan Heavy Polishing - DA PadHook & Loop
H2O-94041 1/4Cyan Heavy Polishing - Spot BuffHook & Loop
H2O-44-2600KR61 1/4Tangerine Light Polishing - KompressorHook & Loop
H2O-2155-130MM5 1/21 1/4Tangerine Light Polishing - DA PadHook & Loop
H2O-2165-152MM6 1/21 1/4Tangerine Light Polishing - DA PadHook & Loop
H2O-2255-130MM5 1/27/8Tangerine Light Polishing - DA PadHook & Loop
H2O-2265-152MM6 1/27/8Tangerine Light Polishing - DA PadHook & Loop
H2O-24041 1/4Tangerine Light Polishing - Spot BuffHook & Loop
H2O-44-1600KR61 1/4Crimson Finishing Pad - KompressorHook & Loop
H2O-1155-130MM5 1/21 1/4Crimson Finishing Pad - DA PadHook & Loop
H2O-1165-152MM6 1/21 1/4Crimson Finishing Pad - DA PadHook & Loop
H2O-1255-130MM5 1/27/8Crimson Finishing Pad - DA PadHook & Loop
H2O-1265-152MM6 1/27/8Crimson Finishing Pad - DA PadHook & Loop
H2O-14041 1/4Crimson Finishing Pad - Spot BuffHook & Loop
这个系列就三种颜色,青蓝色,橙色,红色。
青蓝色抛光/研磨,橙色还原/镜面,红色上蜡/封体。
新糖果
浙江绍兴
89083134 发表于 2013-11-29 13:27
Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad
既然是FINISH,而且这个系列总共也就蓝橙 ...
亲,我查到了……“has very light polishing ability”
78-425505 1/27/8CCS-Gold Ultra FinishingHook & Loop
78-44650DA6 1/21 1/4CCS-Gold Ultra FinishingHook & Loop
76-4165-152mm6 1/21 1/4Gold Ultra FinishingHook & Loop
78-4165CCS-152mm6 1/21 1/4CCS-Gold Ultra FinishingHook & Loop
根据LC的颜色指示,上面这种级别的才是完全无切削力的。
89083134 发表于 2013-11-29 13:34
恩,PRE-WAX用用就OK了,上蜡还是别用这个了......
这个系列海绵偏硬还不怎么便宜......
其实我也奇怪,价格是其次的,为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?为啥上蜡要用机器?
franklee628 发表于 2013-11-29 15:10
IP2100 http://www.menzerna.com/fileadmi ... obil/TDS_IP2100.pdf
没看出太多亮点来,估计是小变化 ...
就像1000#砂纸,可以用1200#打磨过之后再用1500#继续磨。最后再到两千,但实际上我们可以1000#打磨完之后,用2000#直接磨。同样可以细化1000#的砂纸痕,用2000#。
一样的道理。
