新产品---22ple
老外最近在玩这个 价格不菲 求科普
这个牌子的镀膜剂比较贵。像vx1 pro就卖59英镑,折合人民币就600RMB吧~~~寄到国内,各种运费关税又被砍了一大截。暂时没敢入手玩。但评价比非常高。弄得我也很想玩玩。至于哪里出产的,我并没有关注过。以下来说说上面几个镀膜剂的资料:
VX1玻璃涂层 - 低溶剂度,高硅含量为所有类型的汽车油漆(普通版,vx1 pro是加强版)
VX1 Pro玻璃涂层 - 无溶剂,二氧化硅含量的增加,所有类型的汽车油漆(传说中是92%的石英含量)
VM1钢圈及金属涂层 - 可承受温度高达摄氏700度(简单地说就是金属表面的镀膜剂)
VR1整形和修剪外套 - 固化弹性弯曲外部塑料(简单地解释就是塑料的专用镀膜剂)
记忆中,这个厂家还有出产水格利姆去离子水过滤器,“终极雪泡沫”非接触式预洗清洁和RaggTopp软顶敞篷清洁护理的产品。有些东西不算很贵。但老外的评价是都觉得不错!
啊~说明一下,那个玻璃涂层的意思,不是说用于玻璃上,而是用在漆面上,固化成型后结成类似玻璃质地的膜层。是一种用于漆面的高硬度高透光的涂料(也算是镀膜剂的一种)
衣袋车流
我是明仔 发表于 2012-12-14 20:06
这个牌子的镀膜剂比较贵。像vx1 pro就卖59英镑,折合人民币就600RMB吧~~~寄到国内,各种运费关税又被砍了一 ...
西大神不是最近不是有样品发吗,前天看到的
西大神是什么东西?
了解很快哦
大连Detail 发表于 2012-12-14 22:51
了解很快哦
其实也不算是最近两三个月出的产品了。只是老外以前没怎么关注这个产品。现在相对火了,所以才多人玩。产品和工具都这样!
衣袋车流
我是明仔 发表于 2012-12-14 22:45
西大神是什么东西?
zhang xi xiao 啊!他有样品可以领 就是这个牌子哦 就行你说的92的活性硅 太牛逼了 吧
衣袋车流
明仔 去领点样品回来试一下{:55:}
李大普
在咱论坛上才知道这个人,他X宝上句话说的真XX恶心!东西再好,技术在好!有用吗?还得看人!
操.........
挖坟害人啊......
新帖里的水都已经泛滥得让人无心阅读了......
老大还是把一定时期的贴锁了吧,免得又被水军顶上来浪费时间去看......
If you are looking to apply an extremely strong protective coating that will leave an incredible layer of gloss simultaneously then the 22ple VX1 Signature Glass Coating is for you.
This product is a truly unique form of protection that is unlike traditional sealants or waxes but applies just as easy.
It protects the surface in a unique way so contamination will not readily stick to the surface.
Later on your wash mitt will glide across the paint with ease, removing the contamination safely and easily.
Water will even bead and roll off the surface like never before, making the drying process faster and safer which reduces the risk of marring the paint!
The protection is strong but also extremely durable making it far superior to traditional waxes and sealants.
While sealants and waxes provide you with up to 6 months of protection, you can expect a whopping 18-24 months with VX1!
If you're worried about the shine don't bother because it is a warm and deep gloss that commands your attention.
Since you're literally applying a glass like coating to the surface you're getting that "hard candy" or "wet" appearance everyone loves.
This coating will truly distinguish your vehicle from others and preserve it's value for years to come.
